16 years agoCan't build project in the NIOS II IDE
--- Quote Start --- --- Quote Start --- --- Quote Start --- Hi, i have a DE1 board with Cyclone II EP2C20.. device. I designed my hardware and add all the required components ...
16 years agoWhen you use out_memory ,in program you should use main() function not alt_main() function !Do you use it correctly?
