12 years agoBus LVDS in Cynclone V
I tried to implement Bus LVDS in Cyclone V. But I Couldn't Analysis & Synthesis with errors as follows. 21207 "OEOUT" port of the single-ended output buffer "pdo:inst2|pdo_wys" is not connected 21207 "OEBOUT" port of the single-ended output buffer "pdo:inst2|pdo_wys" is not connected I have already read the AN 522 document, but the problem is not solved. I used both Quartus II version 13.1. and 13.0 SP1. When I tried to do it in other device, Cyclone iii and Arria ii, Analysis & Synthesis was succeeded. Do I need an extra step in Cyclone V ? Thank you for help.3 Replies
Bus LVDS is not supported in Cyclone V.
This is a IO limitation, not a tool limitation. (It sucks I know) To do this with Cyclone V you need to use two physical pins, and LVDS_TX with OE, and LVDS_RX pins physically externally connected together. If you check the Cyclone V handbook, you will see it doesn't mention BUS LVDS Pete - Altera_Forum
Quick note: I just double checked the handbook. Looks like it may be a bit more complicated than that. In you may need to use the "Emulated LVDS mode" since it states the true LVDS mode doesn't support tristate.
Pete - Altera_Forum
Thanks for your reply.
I see Cyclone V doesn't support Bus LVDS and tristate. Therefore I will use 2.5-V Differential SSTL instead of BLVDS I/O standard. The following document states Bus LVDS can be implemented in Cynclone V using with 2.5-V Differential SSTL. Is it not right? http://www.altera.com/literature/an/an522.pdf
