12 years agoBus LVDS in Cynclone V
Hi, I tried to implement Bus LVDS in Cyclone V. But I Couldn't Analysis & Synthesis with errors as follows. 21207 "OEOUT" port of the single-ended output buffer "pdo:inst2|pdo_wys" is not...
12 years agoThanks for your reply.
I see Cyclone V doesn't support Bus LVDS and tristate. Therefore I will use 2.5-V Differential SSTL instead of BLVDS I/O standard. The following document states Bus LVDS can be implemented in Cynclone V using with 2.5-V Differential SSTL. Is it not right? http://www.altera.com/literature/an/an522.pdf
