12 years agoBus LVDS in Cynclone V
Hi, I tried to implement Bus LVDS in Cyclone V. But I Couldn't Analysis & Synthesis with errors as follows. 21207 "OEOUT" port of the single-ended output buffer "pdo:inst2|pdo_wys" is not...
12 years agoBus LVDS is not supported in Cyclone V.
This is a IO limitation, not a tool limitation. (It sucks I know) To do this with Cyclone V you need to use two physical pins, and LVDS_TX with OE, and LVDS_RX pins physically externally connected together. If you check the Cyclone V handbook, you will see it doesn't mention BUS LVDS Pete
