20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
Attached is a port of the Microtronix 2.6.11 Nios2 patch to kernel 2.6.15.6-uc0.
I believe the patch should be fairly complete, with module loading, ethernet (91c111), mtd, compact flash, usb, i2c e.t.c. NB: usb and i2c support is not tested on HW. - Atle - Altera_Forum
--- Quote Start --- originally posted by hippo@Jan 11 2006, 12:35 PM 9. you should try out the new kernel.follow step5, build kernel as before, but "cd ~/linux-2.6.15.4" .
if you will develop drivers, you should use the new kernel. --- Quote End --- While testing the new kernel, I discovered that "socket.h" needs a patch. Also, the SMC91111 driver is missing its header file. This soon becomes apparent when you enable Networking -> Networking support, then attempt to build new kernel. Save the following as ~/download/linux-nios2-03.diff
Apply the patch as follows....--- include/asm-nios2nommu/socket.h 2006-03-10 11:50:53.000000000 +1000 +++ include/asm-nios2nommu/socket.h 2006-03-10 11:39:14.000000000 +1000 @@ -38,6 +38,8 @@ # define SO_BROADCAST 6 # define SO_SNDBUF 7 # define SO_RCVBUF 8 +#define SO_SNDBUFFORCE 32 +#define SO_RCVBUFFORCE 33 # define SO_KEEPALIVE 9 # define SO_OOBINLINE 10 # define SO_NO_CHECK 11
Pls let me know how it goescd ~/linux-2.6.15.4 # Patch socket.h patch -p0 <~/download/linux-nios2-03.diff # Salvage the missing SMC91111 header file cp ~/linux-2.6.x/drivers/net/smc91111.h drivers/net # Config the kernel make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- menuconfig # Compile the kernel make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- - Altera_Forum
cd ~/uClinux-dist-test
make menuconfig - Altera_Forum
In post# 1, hippo wrote....
<div class='quotetop'>QUOTE </div> --- Quote Start --- [11. Add user apps ported to uClinux from uClinux-dist. In menuconfig, select Kernel/Library/Defaults Selection ---> [*] Customize Vendor/User Settings (NEW)[/b] --- Quote End --- But I don't see 'Kernel/Library/Defaults Selection' option in menuconfig (ie. version 2.6..15.4). Any ideas what I'm doing wrong? - Altera_Forum
Hi Alex,
I think the problem may be stack overflow, because the elf2flt's default stack is 4K. So please change boa's stack to 32K. "nios2-linux-uclibc-flthdr -s 32000 ~/rootfs/bin/boa" - Altera_Forum
Hi dumdan,
The read-only rom partition is TOTALLY NOT REQUIRED. You should copy the content of your rom partition into ~/rootfs. The initramfs is much better and easier than romfs. So just use the default kernel2.config as .config for kernel. It will save you a lot of time. The cfi and mtd will be required ONLY when you need a read/write flash partition , such as jffs2. You need a proper map for mtd to work. - Altera_Forum
--- Quote Start --- originally posted by hippo@Feb 21 2006, 11:19 AM hi dumdan,you are very close to sucess.
1. start with minimal kernel config, (copy kernel2.config to .config).
2. check if you have network support and your opencore emac / tdk phy in kernel menuconfig, better compile-in kernel, instead of modules.
ie, minimal config + network + emac + phy
3. cfi, mtd,ramdisk,and kernel command line are not required in kernel config, because we use initramfs.
4. boot uclinux, and check if the eth0 init sucessfully.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12846)
--- quote end ---
--- Quote End --- Hi hippo, Thanks for the prompt answer. You see, my network driver is not really ready, yet. So, for my tests I configured the kernel without network support (NO NET). For the network part I was, mostly, concerned with why I still see some netwiork messages. The network is not a major concern of mine, just yet. Now, I know the goal here is to be able to use initramfs and, because of that, the cfi & mtd-related messages are what i'm concerned about. " ..... failed to ioremap ..... mtd: partition "romfs" is out of reach -- disabled .... " Where do these come from and what (if anything) should I do about them ? (of course, I could read the sources and figure out for myself, but the time I have is very, very limitted) Also, I am going to need access to the flash in the very near future, so I'd like to be able to mount readonly a flash partition, if at all possible. That's why I did not totaly removed the MTD and CFI options. What would be the minmal options to be able to access the AMD flash on the eval board and nothing else ? Thanks again, Daniel
Hi Alex,
1. Are you running linux-2.6.15.4? Please try linux-2.6.x first. 2. Is the httpd, which sucessed, from busybox? 3. should boa.conf and mime.types be placed in rootfs/etc ? 4. try check some debug messages from boa. ..I am really not good at network, sorry. - Altera_Forum
HI dumdan,
You are very close to sucess. 1. start with minimal kernel config, (copy kernel2.config to .config). 2. check if you have network support and your opencore emac / tdk phy in kernel menuconfig, better compile-in kernel, instead of modules. ie, minimal config + network + emac + phy 3. cfi, mtd,ramdisk,and kernel command line are not required in kernel config, because we use initramfs. 4. boot uclinux, and check if the eth0 init sucessfully. - Altera_Forum
I make the http and boa in uclinux-dist-test and successed.
Then I copy boa.config to /rootfs/etc/config/ after I reworked the original boa.config. I make dir /rootfs/home/httpd and I put my index.html in the dir. copy boa and http exec file to /rootfs/bin. make kernel again for intramfs. I download the vmlinux to cyclone1c20 dvb,and it init ok. I can visit index.html in dvb when I use http as webserver. But when I use boa as webserver, the uclinux will restart when I viset it use IE.
