20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years agoHi dumdan,
The read-only rom partition is TOTALLY NOT REQUIRED. You should copy the content of your rom partition into ~/rootfs. The initramfs is much better and easier than romfs. So just use the default kernel2.config as .config for kernel. It will save you a lot of time. The cfi and mtd will be required ONLY when you need a read/write flash partition , such as jffs2. You need a proper map for mtd to work.
