20 years agobuildroot to build toolchain on Linux
TO_BE_DONE
20 years ago --- Quote Start --- originally posted by hippo@Feb 21 2006, 11:19 AM hi dumdan,
you are very close to sucess.
1. start with minimal kernel config, (copy kernel2.config to .config).
2. check if you have network support and your opencore emac / tdk phy in kernel menuconfig, better compile-in kernel, instead of modules.
ie, minimal config + network + emac + phy
3. cfi, mtd,ramdisk,and kernel command line are not required in kernel config, because we use initramfs.
4. boot uclinux, and check if the eth0 init sucessfully.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12846)
--- quote end ---
--- Quote End --- Hi hippo, Thanks for the prompt answer. You see, my network driver is not really ready, yet. So, for my tests I configured the kernel without network support (NO NET). For the network part I was, mostly, concerned with why I still see some netwiork messages. The network is not a major concern of mine, just yet. Now, I know the goal here is to be able to use initramfs and, because of that, the cfi & mtd-related messages are what i'm concerned about. " ..... failed to ioremap ..... mtd: partition "romfs" is out of reach -- disabled .... " Where do these come from and what (if anything) should I do about them ? (of course, I could read the sources and figure out for myself, but the time I have is very, very limitted) Also, I am going to need access to the flash in the very near future, so I'd like to be able to mount readonly a flash partition, if at all possible. That's why I did not totaly removed the MTD and CFI options. What would be the minmal options to be able to access the AMD flash on the eval board and nothing else ? Thanks again, Daniel
