14 years ago
Building RBF with SOF and ELF, External SDRAM
Hi All, I am looking for information on how to concatenate a .elf and a .sof file into a single .rbf file. The elf file loads Nios data and instructions into an external SDRAM. Any information/suggestions would be most appreciated.
thanks. V
    Well, I don't do those --create-lanes or --record, plus I am not sure about the hex length... Afaik I set it maximum possible. Anyway, the last thing that should do the job: did You enable memory contents initialization in on-chip ram and set the bootloader hex file You've generated before?
    Post the on-chip memory properties window screenshot.
    --- Quote Start ---
    Did You set the reset and exceptions pointers correctly? Also did You correctly generate hex file from elf file?
    --- Quote End ---
    I assume that the reset vector should be offset 0 of the on-chip memory. What is the exception vector supposed to be? Right now I have it pointing to the sdram.
    I have been using this command to generate the hex file, and have it set in the on-chip RAM to load, and the RAM summary after compilation confirms this:
    elf2hex bootloader.elf <on chip ram start in SOPC> <on chip ram end in SOPC> --width=32 --create-lanes=0 --record=4 ../../bootloader.hex
    --- Quote Start ---
    Yes, You need a bootloader, which would fit into on-chip memory. This bootloader will have to copy Nios program from flash to SDRAM and start it.
    --- Quote End ---
    I am having a hard time getting this to work. I've tried quite a few approaches and the closest I've gotten is using the advanced boot loader in AN 458. I've reached a point where I can program the FPGA with the .pof file with just the hardware system, then download the bootloader app through nios EDS and that works almost. If I put the bootloader app's hex file into the on-chip RAM initialization, then it freezes within the first couple of seconds on power-up, never changing LEDs to indicate it's loading code, but an LED does come on indicating that the program started, rather than when I download the code and executes all the way through. With JTAG output enabled, it prints out 1 1/2 lines of stars then crashes. Disabling the JTAG in the code and in the BSP editor didn't seem to make a difference.
    Even when I download the working bootloader, it can't find my design which I programmed in with the AN 458 instructions at the first design offset. I've tried both loading it right in from the CFI flash and loading it in via on-chip memory.
    I appreciate your help.
    --- Quote Start ---
    How do You do that? You mean You generate SOF file, which has on-chip memory initialization file inside? If yes, then Nios CPU has to have startup vectors to point to on-chip memory.
    NO. You need to add on-chip memory as I've mentioned in (1), then write a small bootloader, which would fit into the on-chip memory and get executed after system startup. That bootloader will have to copy all the required program data to SDRAM and jump to that place.
    Yes, I use on-chip memory of 8KB size with my 4.2KB bootloader pre-compiled. The bootloader copies all the Nios binary from serial flash to SDRAM and executes the main program.
    --- Quote End ---
    I have a Nios program too big to fit into on-chip memory (similar to simple socket server). I have external SDRAM and flash with active parallel setup (no EPCS). Do I also need a bootloader?
    --- Quote Start ---
    1. If I build an SOF with the nios elf file included, can it be converted to an RBF that will initialize the nios memory?
    --- Quote End ---
    --- Quote Start ---
    2. If nios memory is in external SDRAM, will the RBF initialize SDRAM?
    --- Quote End ---
    --- Quote Start ---
    3. Has anyone done this?
    --- Quote End ---
    I'm aware that Quartus already does RBF file output. There are some finer points that i'm curious about.
    Best regards, V
    Quartus already does RBF file output, You have to select an option to enable rbf generation. For ELF, You need to convert it to HEX using elf-to-hex and later You need a 3rd party tool to convert HEX to BIN. Remember, that RBF file is LSB 1st afaik, so You need to do a bit swap.
