14 years agoBuilding RBF with SOF and ELF, External SDRAM
Hi All, I am looking for information on how to concatenate a .elf and a .sof file into a single .rbf file. The elf file loads Nios data and instructions into an external SDRAM. Any information/sugges...
14 years ago --- Quote Start --- 1. If I build an SOF with the nios elf file included, can it be converted to an RBF that will initialize the nios memory? --- Quote End --- How do You do that? You mean You generate SOF file, which has on-chip memory initialization file inside? If yes, then Nios CPU has to have startup vectors to point to on-chip memory. --- Quote Start --- 2. If nios memory is in external SDRAM, will the RBF initialize SDRAM? --- Quote End --- NO. You need to add on-chip memory as I've mentioned in (1), then write a small bootloader, which would fit into the on-chip memory and get executed after system startup. That bootloader will have to copy all the required program data to SDRAM and jump to that place. --- Quote Start --- 3. Has anyone done this? --- Quote End --- Yes, I use on-chip memory of 8KB size with my 4.2KB bootloader pre-compiled. The bootloader copies all the Nios binary from serial flash to SDRAM and executes the main program.
