14 years agoBuilding RBF with SOF and ELF, External SDRAM
Hi All, I am looking for information on how to concatenate a .elf and a .sof file into a single .rbf file. The elf file loads Nios data and instructions into an external SDRAM. Any information/sugges...
14 years agoWell, I don't do those --create-lanes or --record, plus I am not sure about the hex length... Afaik I set it maximum possible. Anyway, the last thing that should do the job: did You enable memory contents initialization in on-chip ram and set the bootloader hex file You've generated before?
Post the on-chip memory properties window screenshot.
