14 years agoBuilding RBF with SOF and ELF, External SDRAM
Hi All, I am looking for information on how to concatenate a .elf and a .sof file into a single .rbf file. The elf file loads Nios data and instructions into an external SDRAM. Any information/sugges...
14 years ago --- Quote Start --- Yes, You need a bootloader, which would fit into on-chip memory. This bootloader will have to copy Nios program from flash to SDRAM and start it. --- Quote End --- I am having a hard time getting this to work. I've tried quite a few approaches and the closest I've gotten is using the advanced boot loader in AN 458. I've reached a point where I can program the FPGA with the .pof file with just the hardware system, then download the bootloader app through nios EDS and that works almost. If I put the bootloader app's hex file into the on-chip RAM initialization, then it freezes within the first couple of seconds on power-up, never changing LEDs to indicate it's loading code, but an LED does come on indicating that the program started, rather than when I download the code and executes all the way through. With JTAG output enabled, it prints out 1 1/2 lines of stars then crashes. Disabling the JTAG in the code and in the BSP editor didn't seem to make a difference. Even when I download the working bootloader, it can't find my design which I programmed in with the AN 458 instructions at the first design offset. I've tried both loading it right in from the CFI flash and loading it in via on-chip memory. I appreciate your help.
