14 years agoBSP editor in Eclipse IDE 11sp1
hi all,
I've recently upgraded from Quartus II 10.1 to 11sp1, because I need to compile the superloop_sss_rgmii_plus example which is developed for this last version. I successfully implement and P&R the example with Quartus, but when I switch to nios IDE, I cannot found the BSP menu and the other altera tools which are presents in the previously versions of the program. I attached a screenshot of nios IDE. The installed version is 11.0sp1 Build 208 with legacy package also (first i didn't install them, but in a second time i installed the package hoping resolving the problem but it didn't happened). In the "About Eclipse" window->installation details, installed software tab I see NiosII software build tools & system console and niosII software build tools for eclipse, so the software is installed; in fact through the niosII command shell I can compile my projects. Anyone has the same problem or know the trick to bypass it? many thanks Alessandro6 Replies
thanks fheineman,
I've reinstalled all QII11sp1 and the NiosII menu in Eclipse is now appeared! I confirm that the legacy package is not necessary. thanks again Ale - Altera_Forum
--- Quote Start --- I don't understand if I have to tick the Legacy package check box... --- Quote End --- I would not check the Legacy package. - Altera_Forum
hi fheineman,
thanks for the reply! I don't understand if I have to tick the Legacy package check box... because if I understand well, this package is useful only for projects created with very old Quartus; for me that I have created projects with QII10.1 is sufficient the Nios II SBT package (that now is automatically installed when you select to install QII). Is that true? thanks again Ale PS: I see also the old post... now I reinstall all:) - Altera_Forum
Hi Ale,
I had the same problem when I first upgraded from version 10.1 to 11.0 of the Quartus II tools. I had to re-install the entire package to solve the problem. I'm not sure if there was a check box that I missed the first time, or just something quirky about the install process (very likely with Altera). Someone else had posted with the same problem previously, so it's not just us. I would try un-installing then re-installing QII 11.0 sp1 and keep a close eye on the check boxes during the process. Good luck! - Altera_Forum
Please put a smaller screenshot, because this one is too big.
