14 years agoBSP editor in Eclipse IDE 11sp1
hi all, I've recently upgraded from Quartus II 10.1 to 11sp1, because I need to compile the superloop_sss_rgmii_plus example which is developed for this last version. I successfully implement an...
14 years agoHi Ale,
I had the same problem when I first upgraded from version 10.1 to 11.0 of the Quartus II tools. I had to re-install the entire package to solve the problem. I'm not sure if there was a check box that I missed the first time, or just something quirky about the install process (very likely with Altera). Someone else had posted with the same problem previously, so it's not just us. I would try un-installing then re-installing QII 11.0 sp1 and keep a close eye on the check boxes during the process. Good luck!
