14 years agoBSP editor in Eclipse IDE 11sp1
hi all, I've recently upgraded from Quartus II 10.1 to 11sp1, because I need to compile the superloop_sss_rgmii_plus example which is developed for this last version. I successfully implement an...
14 years agohi fheineman,
thanks for the reply! I don't understand if I have to tick the Legacy package check box... because if I understand well, this package is useful only for projects created with very old Quartus; for me that I have created projects with QII10.1 is sufficient the Nios II SBT package (that now is automatically installed when you select to install QII). Is that true? thanks again Ale PS: I see also the old post... now I reinstall all:)
