15 years ago
Binary to Binary coded deicmal help
Hi guys,
I'm having trouble implementing a double dabble algorithm in verilog. These modules are supposed to produce 8bit BCD output from 5bit binary input.
However, it seems like the binary goes through unchanged! Which I assume means +3 never happens... But why? Any ideas?
Thanks in advance, the code I've got so far is below.
module bcd(binary, bcd);
    input binary;
    output bcd;
    wire w0,w1,w2,w3;
    assign w0 = binary;
    add3 (.in(w0<<3), .out(w1));
    add3 (.in(w1<<1), .out(w2));
    add3 (.in(w2<<1), .out(w3));
    assign bcd = w3;
endmodule
module add3( in, out);
    input in;
    output out;
    reg out;
    always@(in)
    begin
        out = in;
        if(in>4) out = out + 3;
    end
endmodule
    --- Quote Start ---
    out = out + 3 implies feedback
    --- Quote End ---
    No it doesn't. It's a simple sequential expression.
    --- Quote Start ---
    I have done it hundreds of times on pen and paper and it's work.
    --- Quote End ---
    I checked one example (dec 22 / hex 16, should give hex 22), and it was wrong.
    --- Quote Start ---
    --- Quote End ---
    TENS|ONES|22
    0000|0000|10110
    0000|0101|10 (third shift) ones>4 so +3
    0000|1000|10 (fourth shift)
    0001|0001| (shift 5)
    0010|0010|
    It works. I didn't invent double dabble.
    Just noticed you are adding 3 to ones yet the code adds 3 to all in bits.
    Shouldn't you say:
    if in(8:5) > 4 out(8:5) = out(8:5)+3; as the tens
    --- Quote Start ---
    Shouldn't you say:
    --- Quote End ---
    Oh my, I can;t believe I didn't spot that in two days! It's working much better now. Still not working great but I can work on that in the morning. Thanks so much!
    Update:
    I removed the final add3 now it works perfectly.
    Here's the final code in working order.
    module bcd(in, out);
        input in;
        output out;
        wire w0,w1,w2,w3;
        assign w0 = in;
        assign w3 = w2 << 1;
        assign out = w3;
    endmodule
    module add3(in, out);
        input in;
        output out;
        reg out;
        always@(*)
        begin
            out = in;
            if(in>4) out = in + 3;
        end
    endmodule
