14 years agobig design uses few resources
I compiled a design a few days ago with a Compilation Report like this: Combinational ALUTs 52,437 Memory ALUTs 0 dedicated logic registers 31,310 T...
14 years agoI am having the same issue. I created a system with multiple processors each having a level 1 debugger. This design did not optimize away all my modules.
Then, I used the same system but removed the debugger from each processor. This design optimized away all my modules. I've taken a look at the .map.rpt file and it certainly shows a lot of removed logic, but I'm not sure what connections I need to make. The only connections to my system (nios_system) are two inputs (clk, and reset_n). These are both connected (I believe?) in my top level module where I instantiate the system. Any ideas?
