Jack_Lin
5 months agoBidirectional pin USB_RX with a pseudo-differential I/O standard must use the OEIN port of the node
I am trying to make a bidirectional differential line using Cyclone V. In VHDL, I set USB_RX, USB_RXn as INOUT on the top level (they are assigned to a Differential SSTL-II 2.5 pair). I used the AL...
- 5 months ago
Hi Jack,
not quite clear what you want to achieve. USB (both FS and HS) is a half-duplex protocol and involves push-pull drivers with enable signal.
Regards Frank
FvM
5 months agoI see same "must use the OEIN port" error when OE is stuck to '0'. OE_B isn't used at all when driving a differential I/O standard.
Jack_Lin
5 months agoThanks. My original idea was to build it up and set it to input/output first to make sure that it compiles before I add more logic to change the directions. But it seems like the reason I am getting the errors is because the differential pins on Cyclone V are not bidirectional and can only get set to either input or output. Will need to check for a different device.
