Jack_Lin
5 months agoBidirectional pin USB_RX with a pseudo-differential I/O standard must use the OEIN port of the node
I am trying to make a bidirectional differential line using Cyclone V. In VHDL, I set USB_RX, USB_RXn as INOUT on the top level (they are assigned to a Differential SSTL-II 2.5 pair). I used the AL...
- 5 months ago
Hi Jack,
not quite clear what you want to achieve. USB (both FS and HS) is a half-duplex protocol and involves push-pull drivers with enable signal.
Regards Frank
Jack_Lin
5 months agothis is the block that Quartus generated and the error is coming from.
