15 years ago
BCD counter vhdl code
I am a newbie quartus user.. please help me thanks
http://i54.tinypic.com/2zp2p3p.png
This is my written code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity d4 is
port (reset, sensor, load :in std_logic;
p :in std_logic_vector (5 downto 0);
led_on :out std_logic;
q :out std_logic_vector (5 downto 0));
end d4;
architecture flow of d4 is
signal count_sig : unsigned (5 downto 0);
signal load_sig : unsigned (5 downto 0);
begin
process (sensor, reset, load, p)
begin
if (reset = '1') then
count_sig <= "000000";
elsif rising_edge (sensor) then
if (count_sig = 32) then
else
count_sig <= count_sig + 1;
if (load = '0') then
count_sig <= load_sig;
else
end if;
end if;
end if;
end process;
q <= std_logic_vector (count_sig);
end flow;
I did not add LED_ON in the code because i don't know the correct way to to put in the LED, always getting error when i try to put in LED code..
and i can't make P to activate Q when load is low.
i don't know what i am talking about too. Please help me ! appreciate if u do so
:confused:
    The code seems right: But you have twice "count_sig <= count_sig + 1;" in the code. But i don't think thats gonna affect the process.
    I should try to adjust the test bench. Make load low for longer than a half a clk period. Make it low for 2 clk periods. Load works on a rising edge and load = '0'.
    I told the reason for load not working in my previous post. Read it again. Or follow the above suggestion, but the waveform would be slightly different from the reference.
    Also the led output is coming one cycle too soon, and with wrong polarity compared to the reference waveform. I also told a suggestion for this point.
    --- Quote Start ---
    --- Quote End ---
    Right, only the last assignment in a process wins, this property is also utilized for the load case. But the double assignment should be removed for clarity.
    FvM and woody allen thanks for ur great help ! i hv got it working like it's suppose to already! thanks !
    oops a minor problem.
    http://i53.tinypic.com/35d6ek8.png
    how to i fix this ?
    library ieee;
    entity d4 is
    p :in std_logic_vector (4 downto 0);
    q :out std_logic_vector (4 downto 0));
    end d4;
    signal count_sig : unsigned (4 downto 0);
    signal led_flag : std_logic;
    begin
    begin
    count_sig <= "00000";
    if count_sig = 31 then
    led_flag <= '1';
    count_sig <= (others => '0');
    else
    led_flag <= '0';
    led_on <= not led_flag;
    count_sig <= unsigned(p);
    end if;
    end if;
    end if;
    end process;
    end flow;
      led <= '1';
      led_flag <= '0';
