15 years agoBCD counter vhdl code
I am a newbie quartus user.. please help me thanks
http://i54.tinypic.com/2zp2p3p.png This is my written code: library ieee;use ieee.std_logic_1164.all;
use ieee.numeric_std.all; entity d4 is
port (reset, sensor, load :in std_logic;
p :in std_logic_vector (5 downto 0);
led_on :out std_logic;
q :out std_logic_vector (5 downto 0));
end d4; architecture flow of d4 is signal count_sig : unsigned (5 downto 0);
signal load_sig : unsigned (5 downto 0); begin
process (sensor, reset, load, p)
begin
if (reset = '1') then
count_sig <= "000000"; elsif rising_edge (sensor) then
if (count_sig = 32) then
count_sig <= "000000"; else
count_sig <= count_sig + 1; if (load = '0') then
count_sig <= load_sig; else
end if;
end if;
end if;
end process;
q <= std_logic_vector (count_sig); end flow;
------------------------------------------------------------------------ I did not add LED_ON in the code because i don't know the correct way to to put in the LED, always getting error when i try to put in LED code.. and i can't make P to activate Q when load is low. i don't know what i am talking about too. Please help me ! appreciate if u do so :confused:
