8 years ago
bbs prng simulation done, but no result waveform
currently i am using Cyclone II family libraries to implement a bbs prng
i have insert a coding that i copy from internet, but i quite confuse on understanding the coding
the coding i'm using to make modification:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity bbs is
Port ( p : in integer;
q : in integer;
s : in integer;
b : out STD_LOGIC_VECTOR(7 downto 0) );
end bbs;
architecture Behavioral of bbs is
begin
process(p,q,s)
variable x0,x1,s1,x_0:integer;
constant p:integer:=11;
constant q:integer:=19;
constant n:integer:=551;
variable b1:integer ;
variable b2:std_logic;
variable r:std_logic_vector(7 downto 0);
begin
s1:=s*s;
x0:=s1 mod 1024;
for i in 0 to 7 loop
x_0:=x0*x0;
x1:=x_0 mod 1024;
b1:=x1 mod 2;
if b1=1 then
b2:='1';
else b2:='0';
end if;
r(6):=r(7);
r(5):=r(6);
r(4):=r(5);
r(3):=r(4);
r(2):=r(3);
r(1):=r(2);
r(0):=r(1);
r(7):=b2;--so it will be serially transmitted but parallelly observed
x0:=x1;
b<=r;
end loop;
end process;
end Behavioral;
please if there is someone can help me on explaining the coding?
    --- Quote Start ---
    No, in the code p, q, s are declared as integer, check screen shot. Output of the given code either 00000000 or 11111111. It depends on the value of b1.
    Refer attached IEEE paper & modify your code.
    Let me know if this has helped resolve the issue you are facing.
    Best Regards
    Vikas Jathar
    Intel Customer Support – Engineering
    (Under Contract to Intel)
    --- Quote End ---
    hi jatharvk, thanks for your helping, seen i just try to design the bbs algorithm, now i will use back my lfsr prng design to continue my FYP project
    appreciate for your helping
    Your sincerely
    Vahn Heng
    --- Quote Start ---
    how you assign the input p, q, and s as 1 bit?
    --- Quote End ---
    --- Quote Start ---
    how can i modify it to show the output in random value form?
    --- Quote End ---
    Best Regards
    Vikas Jathar
    hi jatharvk, thanks for your information
    i refer to your sreenshot, how you assign the input p, q, and s as 1 bit?
    because when i assign p, q and s node into the quartus II waveform window, it show 3 of these nodes are in 32 bits
    and since i need my output should be in random value, the output result is only showed as "00000000" and "11111111"
    Try to simulate and understand the operation, Also refer the following points,
    In given code input ‘s’ has significance.
    Check operation of Mod operator.
    When s=0 leads to b1=0 so b2 =0 hence r<=b<=00000000,
    When s=1 leads to b1=1 so b2 =1 hence r<=b<=11111111.
    --- Quote Start ---
    --- Quote End ---
    In for loop, eventually output vector b (b<=r) is updated, Check screen shot.
    Best Regards
    Vikas Jathar
