8 years agobbs prng simulation done, but no result waveform
currently i am using Cyclone II family libraries to implement a bbs prng i have insert a coding that i copy from internet, but i quite confuse on understanding the coding the coding i'm using...
8 years agohi jatharvk, thanks for your information
i refer to your sreenshot, how you assign the input p, q, and s as 1 bit? because when i assign p, q and s node into the quartus II waveform window, it show 3 of these nodes are in 32 bits and since i need my output should be in random value, the output result is only showed as "00000000" and "11111111" how can i modify it to show the output in random value form?
