8 years agobbs prng simulation done, but no result waveform
currently i am using Cyclone II family libraries to implement a bbs prng i have insert a coding that i copy from internet, but i quite confuse on understanding the coding the coding i'm using...
8 years ago --- Quote Start --- Hi, No, in the code p, q, s are declared as integer, check screen shot. Output of the given code either 00000000 or 11111111. It depends on the value of b1. Refer attached IEEE paper & modify your code. Let me know if this has helped resolve the issue you are facing. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel) --- Quote End --- hi jatharvk, thanks for your helping, seen i just try to design the bbs algorithm, now i will use back my lfsr prng design to continue my FYP project appreciate for your helping Your sincerely Vahn Heng
