8 years agobbs prng simulation done, but no result waveform
currently i am using Cyclone II family libraries to implement a bbs prng i have insert a coding that i copy from internet, but i quite confuse on understanding the coding the coding i'm using...
8 years agoHi,
--- Quote Start --- how you assign the input p, q, and s as 1 bit? --- Quote End --- No, in the code p, q, s are declared as integer, check screen shot. Output of the given code either 00000000 or 11111111. It depends on the value of b1. --- Quote Start --- how can i modify it to show the output in random value form? --- Quote End --- Refer attached IEEE paper & modify your code. Let me know if this has helped resolve the issue you are facing. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel)
