Avalon mm pipeline bridge problem: multible write
Im using CycloneVsoc link lwh2f(32bit) ---> Avalon mm pipeline bridge(32bit) -----> MyIP core(8bit)
the following is the signal tap result:
When I ran alt_write_byte for one time in the timer IRQ.
Here is my verilog logic:
The port reset_wr here should be only one pulse signal when I wrote to the FPGA module.
The other problem is that writedata signal should be at 0b01---->0b11------->0b01------> loop
yet signal tap didnt catch the value.
It change from 01 to 00 for severial times.
Writedata[1] should be at 0 until I write.
Could you please help me with that?
Thank you.
Reguards
Alex
- sstrell
assign irq_signal = irq_en & reset_assert; always @(posedge clk or negedge reset_n) begin if (reset_n == 1'b0) irq_en <= 1'b0; else if (write) if (writedata[0]) irq_en <= 1'b1; else irq_en <= 1'b0;Your "write" signal is essentially a synchronous clock enable for the register and writedata[0] is a synchronous set. You just have to cover both cases for it. This should now synthesize correctly.
- sstrell
You don't specify in your HDL what irq_en should be when write is low, so you've basically created a latch.
But I don't understand why in your Signal Tap capture writedata[1] does not match what is shown for writedata[7..0]. Are you sure you are tapping the correct signals or accidentally tapping a different writedata[1]?
- CAlex
Contributor
Hi
irq_en is what I want to have,
reset_wr signal is not, I didnt expect 4 write signal when using alt_write_byte().
And yes, they are the same signal, which makes this case stranger.
- sstrell
You do not want to have a latch, especially in an FPGA design. They make it difficult to meet timing and can cause glitching. That could be part of this problem depending on how irq_en is working with the rest of the design.
As for the weird writedata, I'd try removing and re-adding the signals in the .stp file or just create a brand new .stp in case the file is corrupt.
