14 years agoassociate signal tap .stp file with a megawizard generated signal tapproject
I add a signal tap component generated with megawizard in my project. I have connected signals on its input : clock, data and trigger signals. Is it possible to create an instance in signaltap II analyzer which integrate automatically megawizard parameters ? When I create an instance manually, I can't run signal tap. The sof manager says that my instance is not compatible with the sof file. I use this method : - set the same clock, sample depth, continuous storage - add signals (data and trigger) connected to the signal tap component (using "signaltap II: pre-synthesis" filter) What is the correct method to use signal tap from a megawizard file and create a valid .stp file? Thanks.2 Replies
I found the solution, the menu was in quartus, not in signal tap analyzer.
So the correct way is: quartusII / file / creat-update / create signal tap II file from design instance - Altera_Forum
Thanks. That's exactly what I need.
--- Quote Start --- I found the solution, the menu was in quartus, not in signal tap analyzer. So the correct way is: quartusII / file / creat-update / create signal tap II file from design instance --- Quote End ---
