14 years agoassociate signal tap .stp file with a megawizard generated signal tapproject
Hi, I add a signal tap component generated with megawizard in my project. I have connected signals on its input : clock, data and trigger signals. Is it possible to create an instance in...
12 years agoThanks. That's exactly what I need.
--- Quote Start --- I found the solution, the menu was in quartus, not in signal tap analyzer. So the correct way is: quartusII / file / creat-update / create signal tap II file from design instance --- Quote End ---
