14 years agoassociate signal tap .stp file with a megawizard generated signal tapproject
Hi, I add a signal tap component generated with megawizard in my project. I have connected signals on its input : clock, data and trigger signals. Is it possible to create an instance in...
14 years agoI found the solution, the menu was in quartus, not in signal tap analyzer.
So the correct way is: quartusII / file / creat-update / create signal tap II file from design instance
