Sungjin
1 year agoAssistance Required: Persistent Oscillation Issues on MAX10 LVDS Receiver Inputs
Hello, I'm currently working with an Intel MAX10 device configured with a 10-lane LVDS interface. However, I’ve been struggling with persistent oscillations occurring at the LVDS receiver inputs. ...
- 1 year ago
I believe the answer is implementation dependent. Adding a DC bias to enforce a 0 or 1 level for floating LVDS inputs would reduce performance, e.g. increase minimal signal level and add an asymmetrical time shift of input signal, reducing effective skew margin. Both effects reduce maximal cable length. Common mode bias is required in AC coupled input circuit, but differential bias is rarely applicable for high speed differential signaling.
When receiving an open LVDS input signal with 10b8b decoder, we still get a certain rate of false correct frames. An additional time filter detects stable input signal.
JohnT_Altera
1 year agoHi,
May I know what is the LVDS speed are you running and the oscillation noise that is observed in your design?
