10 years agoArria10 HPS Fpga to Sdram cannot be configured above 64 bits
Hi All,
I want to use the fpga to sdram path in Arria 10 HPS. I want to connect a 256bit AXI interface operating at 125 Mhz from a third party IP to this port. I had a couple of questions:- I cannot select a 256 bit data width in HPS parameter editor. The maximum I can go upto is 64bits.
- If I want to work with 64bit data port but still match the bandwidth (32 Gbps = 256 bits * 125 Mhz) of third party IPs AXI interface, how can I really do it ?
- How do we decide the frequency of the clock for this fpga-to-sdram port.
- Which DDR protocol will QSYS configure in the DDR controller. Will it be DDR3 or DDR4. How does Qsys decide this anyway?
--- Quote Start --- I am sorry,but how do you identify that? --- Quote End --- You can read the part number at the board. as i know there is some issue with the board which is having the ES1 chip. where currently maximum you can do is 64 bit only.. so please be aware that newer board already fixed this limitation. - Altera_Forum
Ok. Thanks Bob and thankyou every one for the replies. This is good amount of info. I will see if I can get a new board replaced from Altera.
