10 years agoArria10 HPS Fpga to Sdram cannot be configured above 64 bits
Hi All, I want to use the fpga to sdram path in Arria 10 HPS. I want to connect a 256bit AXI interface operating at 125 Mhz from a third party IP to this port. I had a couple of questions: ...
10 years ago --- Quote Start --- I am sorry,but how do you identify that? --- Quote End --- You can read the part number at the board. as i know there is some issue with the board which is having the ES1 chip. where currently maximum you can do is 64 bit only.. so please be aware that newer board already fixed this limitation.
