GerhardCadek
2 months agoArria 10SX current drawn during non-volatile key programming
Hi, we are using in our design an Arria10 SX (precisely the 10AS027E4F29E3SG) device. The design had been successfully manufactured for approx. 100 units. For one customer we decided to use design s...
Farabi_Altera
1 month agoHello,
I checked with validation team. There is no data on power consumption during programming non-volatile key. This is because the power consumption to program non-volatile key supposed to be not exceed the power consumption during user mode.
The non-volatile key programming stage is before the configuration stage, and the power consumption for programming non-volatile key will not exceed the power in user mode(where all the IOs are active, clock are toggling at highspeed etc). You are designing the power delivery network based on user mode, not based on programming power where all the IOs and clocks are inactive.
regards,
Farabi
