GerhardCadek
2 months agoArria 10SX current drawn during non-volatile key programming
Hi, we are using in our design an Arria10 SX (precisely the 10AS027E4F29E3SG) device. The design had been successfully manufactured for approx. 100 units. For one customer we decided to use design s...
GerhardCadek
2 months agoHi,
VCCPT is shared with VCCIOREF_HPS, VCCA_PLL, VCCH_GXBL, VCCPLL_HPS. PDN had not been used. We do not see any power nor current issue under normal conditions. We see unexpected current and voltage drop while programming the non-volatile key. Thus I am looking for the spec of this current. Without these numbers we cannot adapt nor model the power distribution.
Gerhard
Farabi_Altera
2 months agoHi,
Current requirement is different from each designs. If you use more IOs, higher speed, it will consume more current, if you use less resource, it will use less current. I can't give the current spec as this is design dependent. The recommendation is to use PDN so the tool will calculate the current consumption of your unique design.
regards,
Farabi
