FabianL
4 months agoArria 10: Remote Update Factory Fallback won't work & Watchdog does not trigger
Hello, I have to reopen another topic from last year: Arria 10: Remote Update may brick FPGA and Factory Fallback won't work | Altera Community - 315011 Opposed to my comments in the orig...
Farabi_Altera
4 months agoHi Fabian,
1- Please dont do the 2-byte offset to trigger the CRC. You should delete some chunk of bitstream data and re-run to trigger the CRC.
2- Can you compare the last 576-bytes of RPD file with your flash last 576-bytes? the contents MUST match if not this area might corrupt and possible the root cause of your fallback failure.
regards,
Farabi
