tt_engineer
7 months agoArria 10 Reconfiguration
I am working with an Arria 10 (10AS048) and using an external FPGA to manage configuration from a flash memory.
When working with a non encrypted image, i am able to configure, then reconfigure, without issue.
When i try to do the same thing with an encrypted image i have success on the initial configuration. Once i try to reconfigure I never get config_done. The A10 never pulls nStatus low to indicate a CRC error. When encryption is used is there something in the A10 that is stopping reconfiguration?
1 Reply
- Farabi_Altera
Are you using non-volatile key to encrypt your design? This is non-reversible flow if you dont have the correct key.
regards,
Farabi
