9 years agoArria 10 reclk frequency limitations of fPLL
When instantiating an fPLL (in Qsys) with a reference clock frequency of 50 MHz the fitter reports the following error:
Error (15653): The Fitter cannot find a legal configuration for the following atoms. Update any outdated transceiver PHY IP cores, correct any illegal pin assignments, and then recompile your design.
Error (15744): In atom 'FS2_Arria:u0|altera_xcvr_fpll_a10:xcvr_fpll_a10_0|fpll_inst'
Error (15744): The settings must match one or more of these conditions:
Error (15744): ( sup_mode == ENGINEERING_MODE ) OR ( prot_mode == UNUSED ) OR ( refclk inside {0:49000000,210000000:68719476735} ) OR {((set_fpll_input_freq_range*36'h00002625a0)>((refclk-36'h0002faf080)-36'h00001312d0))}
Error (15744): But the following assignments violate the above conditions:
Error (15744): pll_sup_mode = USER_MODE
Error (15744): prot_mode = BASIC_TX
Error (15744): reference_clock_frequency_scratch = 50000000
The target device is an Arria 10 and I use the fPLL in Core mode, i.e. I don't use it for a transceiver but for synthesizing some user clock. The error message suggests that I have to change on of the parameters sup_mode, prot_mode or refclk. However - sup_mode ist not meant to be changed by the user (it is also not accessible from Qsys)
- UNUSED is not a valid value for parameter prot_mode
This is a known bug (https://www.altera.com/support/support-resources/knowledge-base/solutions/fb371226.html): the reference frequency must be outside [49 MHz, 51.5 MHz].
Can I set the reference clock frequency parameter to 48 MHz when the actual frequency is 50 MHz? - Altera_Forum
The desired output frequency is 24 MHz. Qsys seems to be ok with that ;)
What's the output clock(s) you are trying to generate from the 50 MHz?
