Arria 10 QSPI controller hangs after U-Boot shell while SPL boots successfully
- 3 months ago
Thank you for your suggestion.
I added several debug prints throughout the U-Boot initialization process in order to determine exactly where the issue occurs.
Here is what I found:
The QSPI controller is initialized successfully.
setup_flash_device() completes successfully.
The SPI NOR device is detected correctly.
The environment is read successfully from flash (spi_flash_read() returns 0).
The only result is a Bad CRC, so U-Boot falls back to the default environment, but the flash controller continues to operate normally.
I also added register reads after the environment loading and confirmed that the QSPI module is still accessible and responding correctly.
The crash actually happened later during the network initialization (initr_net()), not during the QSPI or environment handling.
After further investigation, I found that the Device Tree still had the Ethernet PHY node enabled (status = "okay"), while this specific board (Combiner Master) does not have a PHY populated.
As a result, U-Boot attempted to initialize a non-existent PHY and eventually crashed. After changing the PHY node to:
status = "disabled";
the issue was completely resolved and U-Boot now boots normally.
Regarding the handoff files, we are already using different handoff (hps.xml) files for each board, generated separately for their respective hardware configurations.
Thank you for your help.
Hi LironAvrhmov
In practice the handoff file should be unique to each boards and be compile together with the uboot for each boards.
If you are sharing the binaries, please avoid that and use the handoff file from each project to compile separate SPL and uboot for the boards.
One thing to try is to check the QSPI Clock enable register and the QSPI Reset register below:
On the failing board try reading the register value and see if the QSPI Clock is enabled and not in reset.
