ALTPLL For Multiple Input Frequencies
Yes you are right. The minimum freq for PLL refclk in Cyclone III device is 5MHz.
There are methods for PLL reconfiguration:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an507.pdf
Eng Wei
Design Example 1 in AN507 shows the PLL being reconfigured with one of three .mif files used to select output frequency. Is there a way - other than manually generating 65,536 .mif files - to achieve what I'm looking to do? Thanks.
- EngWei_O_Intel5 years ago
Hi @BigSid
You can also reconfigure the PLL according to method 1 in
Eng Wei
Hi @BigSid
I am transferring this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
- GLees5 years ago
Contributor
I have found that the PLL lock range can be as great as 2:1, so you probably don't need 65535 reconfigurations. Maybe only 4-8 are required.
