9 years agoALTPLL for multiple input frequencies
Hi All,
I have an input clock to MAX-10, which could be 2.5MHz, 25MHz, and 250MHz. I need to put a PLL on this input clock (for shifting the input clock by 90 degrees). I don't have any indication what clock (frequency) is currently connected to the pin. So, how should I configure the ALTPLL? What frequency should I define? What Mode (normal, clock synchronous, etc). Thank you!4 Replies
125Mhz default sounds correct.
Hi, gj_leeson!
I have the same problem: on one pin may be clock 25MHz or 125MHz and I have a pin, which indicates this - 0 for 25 and 1 for 125. I read altera manuals about altpll_reconfig with several mif-files. I create the same scheme with two ROMs, MUX, pll_reconfig and pll. I create two mif-files from pll wizard for two input clocks. And my question: how should I configure the pll? The default PLL settings are for 125MHz, because this situation is more difficult for scheme and TimeQuest timing analyzer. Am I right or not? What would you advise in this case? Thanks! - Altera_Forum
If you can design some logic for determining which of the three frequencies is present, you can dynamically reconfigure the PLL to work with that frequency.
Altera PLLs have a maximum lock range of about 1:2. Also constraints for PFD frequency range.
Changing input frequency over a wider range would require PLL reconfiguration or multiple PLLs. Also input frequency of 2.5 MHz is below specified MAX10 range.
