9 years agoALTPLL for multiple input frequencies
Hi All, I have an input clock to MAX-10, which could be 2.5MHz, 25MHz, and 250MHz. I need to put a PLL on this input clock (for shifting the input clock by 90 degrees). I don't have...
9 years agoAltera PLLs have a maximum lock range of about 1:2. Also constraints for PFD frequency range.
Changing input frequency over a wider range would require PLL reconfiguration or multiple PLLs. Also input frequency of 2.5 MHz is below specified MAX10 range.
