14 years agoALTMEMPHY Debug GUI: Fails Read Resynch Phase Cal Rst
I'm debugging a DDR2 SO-DIMM design that doesn't work (the example top design seemingly doesn't do anything). I enabled the debug interface per the EMI handbook (debug section) and ran the Debug GUI. The stage 'Read resynchronisation phase calibration - reset' fails with result code 0xa2177307.
Any idea where to start looking for errors? Would it make sense to lower the speed of the DDR2 interface (currently 200 MHz on an Arria II GX)? Any other tips? The only possible relevant warning is the following from analysis & synthesis: Warning: PLL "HPC1_example_top:inst1|HPC1:HPC1_inst|HPC1_controller_phy:HPC1_controller_phy_inst|HPC1_phy:HPC1_phy_inst|HPC1_phy_alt_mem_phy:HPC1_phy_alt_mem_phy_inst|HPC1_phy_alt_mem_phy_clk_reset:clk|HPC1_phy_alt_mem_phy_pll:half_rate.pll|altpll:altpll_component|altpll_u9p3:auto_generated|pll1" has parameters clk2_multiply_by and clk2_divide_by specified but port CLK[2] is not connected Is this normal? The .doom file is attached.
