12 years agoAlterra embedded example::>Altera-SoCFPGA-HardwareLib-FPGA-CV-ARMCC::>FAIL ONRESET A9
Hi guys,
I am getting a "fail in trying to reset A9 cortex processor" on the sockit cyclone V board. Basically I compiled the example project altera-socfpga-hardwarelib-fpga-cv-armcc but when I try to start with debug I get this error (see attached...) Any ideas/sugestion -antonioa4 Replies
Which development board are you using? Altera or Arrow?
I was getting same error with Arrow board last week and I managed to run parts of HardwareLib example on my HW project (I did a simple blinky). But since I have a lot of other thing to do I left it in drawer for a while. Note that you have a line which says: No SYSID register found... Perhaps there is a Sys Id module missing in your Qsys or you didn't supply the right .svd file to the debugger. - Altera_Forum
Hi janco,
I am using http://www.altera.com/b/arrow-sockit.html. I do not understand the difference you meant: Altera or Arrow? They are both proprietaries HW+SW stuff, I think... Anyway, for sure there is something wrong. I would like to better understand the design flow to get this application working. The example "Altera-SoCFPGA-HardwareLib-FPGA-CV-ARMCC" gives some HOWTO to set up the board and then simply says to launch the debug configuration from DS-5. So what I do is: - import the proj file from AlteraFolder to DS-5. No upload FPGA configuration on board, no Quartus, no Qsys and so on... just importing this project. - compile it - open debug configuration just to set Altera->...->Bare-metal application->USBlaster II as connection method - run Debug At this point I get that error on the debug perspective. Do I have to configure the FPGA+HPS in such way before to do this? The fact is that it seems that this project after compilation has been able to produce all needed stuff (.sof files and debug-hosted.ds). So I was wondering if it should work without any other configuration... Please help me guys, I know it is a stupid problem... thank you antonio - Altera_Forum
Sorry for a late reply,
Yes, apparently you are using Arrow board. Altera has it's own development board: cyclone v soc development kit (http://www.altera.com/products/devkits/altera/kit-cyclone-v-soc.html) and the examples are made for that board (note small differences in names between them, for HardwareLib example's readme.txt mentiones MSEL, on Arrow board it is called BOOTSEL). There are 3 modes of booting the system:- FPGA first
- HPS first
- Independent
# include <stdio.h> # include "alt_address_space.h" # include "alt_bridge_manager.h" # include "alt_clock_manager.h" # include "alt_reset_manager.h" # include "alt_dma.h" # include "socal/socal.h" # include "hwlib.h" /*#include "hw_inits.h"*/ # include "pll_config.h" # include "clock_manager.h" # include "socfpga_base_addrs.h" //#define ALT_FPGA_ENABLE_DMA_SUPPORT /* // Protoype definition of main() int main(int argc, char** argv); //---------------------------------------- // ENTRY POINT //--------------------------------------- int __main(void){ main(0,0); return 0; }*/ # define ALT_LWFPGA_BASE 0xFF200000 # define ALT_LWFPGA_SYSID_OFFSET 0x00010000 # define ALT_LWFPGA_LED_OFFSET 0x00010040 # define DW_WDT_CR 0x00 # define DW_WDT_TORR 0x04 # define DW_WDT_CRR 0x0C # define DW_WDT_CR_EN_OFFSET 0x00 # define DW_WDT_CR_RMOD_OFFSET 0x01 # define DW_WDT_CR_RMOD_VAL 0x00 # define DW_WDT_CRR_RESTART_VAL 0x76 int i=0; void delay(int loops){ for(i=0; i<loops;i++){ __asm__("nop"); } } int main(int argc, char** argv) { // //ALT_DMA_CHANNEL_t channel; printf("Hello from Semi-Hosted ARMCC Baremetal Altera SoC-FPGA!\n"); ALT_STATUS_CODE status = ALT_E_SUCCESS; if( status == ALT_E_SUCCESS) { status = alt_bridge_init(ALT_BRIDGE_F2H,0,0); } else { while(1); // catch error } if( status == ALT_E_SUCCESS) { status = alt_bridge_init(ALT_BRIDGE_H2F,0,0); } else { while(1); // catch error } if( status == ALT_E_SUCCESS) { status = alt_bridge_init(ALT_BRIDGE_LWH2F,0,0); } else { while(1); // catch error } if( status == ALT_E_SUCCESS) { status = alt_addr_space_remap(ALT_ADDR_SPACE_MPU_ZERO_AT_BOOTROM, ALT_ADDR_SPACE_NONMPU_ZERO_AT_OCRAM, ALT_ADDR_SPACE_H2F_ACCESSIBLE, ALT_ADDR_SPACE_LWH2F_ACCESSIBLE); } else { while(1); // catch error } while(1){ alt_write_word(ALT_LWFPGA_BASE + ALT_LWFPGA_LED_OFFSET, 0x3); delay(10000); alt_write_word(ALT_LWFPGA_BASE + ALT_LWFPGA_LED_OFFSET, 0x0); delay(10000); // reset watchdog timer alt_write_word((SOCFPGA_L4WD0_ADDRESS + DW_WDT_CRR), DW_WDT_CRR_RESTART_VAL ); } return 0; } - Altera_Forum
Hi antonioa,
I have the same problem with the arrow sockit. Did you solved It?
