12 years agoAlterra embedded example::>Altera-SoCFPGA-HardwareLib-FPGA-CV-ARMCC::>FAIL ONRESET A9
Hi guys, I am getting a "fail in trying to reset A9 cortex processor" on the sockit cyclone V board. Basically I compiled the example project altera-socfpga-hardwarelib-fpga-cv-armcc but when...
12 years agoHi janco,
I am using http://www.altera.com/b/arrow-sockit.html. I do not understand the difference you meant: Altera or Arrow? They are both proprietaries HW+SW stuff, I think... Anyway, for sure there is something wrong. I would like to better understand the design flow to get this application working. The example "Altera-SoCFPGA-HardwareLib-FPGA-CV-ARMCC" gives some HOWTO to set up the board and then simply says to launch the debug configuration from DS-5. So what I do is: - import the proj file from AlteraFolder to DS-5. No upload FPGA configuration on board, no Quartus, no Qsys and so on... just importing this project. - compile it - open debug configuration just to set Altera->...->Bare-metal application->USBlaster II as connection method - run Debug At this point I get that error on the debug perspective. Do I have to configure the FPGA+HPS in such way before to do this? The fact is that it seems that this project after compilation has been able to produce all needed stuff (.sof files and debug-hosted.ds). So I was wondering if it should work without any other configuration... Please help me guys, I know it is a stupid problem... thank you antonio
