12 years agoAlterra embedded example::>Altera-SoCFPGA-HardwareLib-FPGA-CV-ARMCC::>FAIL ONRESET A9
Hi guys, I am getting a "fail in trying to reset A9 cortex processor" on the sockit cyclone V board. Basically I compiled the example project altera-socfpga-hardwarelib-fpga-cv-armcc but when...
12 years agoSorry for a late reply,
Yes, apparently you are using Arrow board. Altera has it's own development board: cyclone v soc development kit (http://www.altera.com/products/devkits/altera/kit-cyclone-v-soc.html) and the examples are made for that board (note small differences in names between them, for HardwareLib example's readme.txt mentiones MSEL, on Arrow board it is called BOOTSEL). There are 3 modes of booting the system:- FPGA first
- HPS first
- Independent
# include <stdio.h>
# include "alt_address_space.h"
# include "alt_bridge_manager.h"
# include "alt_clock_manager.h"
# include "alt_reset_manager.h"
# include "alt_dma.h"
# include "socal/socal.h"
# include "hwlib.h"
/*#include "hw_inits.h"*/
# include "pll_config.h"
# include "clock_manager.h"
# include "socfpga_base_addrs.h"
//#define ALT_FPGA_ENABLE_DMA_SUPPORT
// Protoype definition of main()
int main(int argc, char** argv);
// ENTRY POINT
int __main(void){
main(0,0);
return 0;
# define ALT_LWFPGA_BASE 0xFF200000
# define ALT_LWFPGA_SYSID_OFFSET 0x00010000
# define ALT_LWFPGA_LED_OFFSET 0x00010040
# define DW_WDT_CR 0x00
# define DW_WDT_TORR 0x04
# define DW_WDT_CRR 0x0C
# define DW_WDT_CR_EN_OFFSET 0x00
# define DW_WDT_CR_RMOD_OFFSET 0x01
# define DW_WDT_CR_RMOD_VAL 0x00
# define DW_WDT_CRR_RESTART_VAL 0x76
int i=0;
void delay(int loops){
for(i=0; i<loops;i++){
__asm__("nop");
int main(int argc, char** argv) {
//ALT_DMA_CHANNEL_t channel;
printf("Hello from Semi-Hosted ARMCC Baremetal Altera SoC-FPGA!\n");
ALT_STATUS_CODE status = ALT_E_SUCCESS;
if( status == ALT_E_SUCCESS) {
status = alt_bridge_init(ALT_BRIDGE_F2H,0,0);
} else {
while(1); // catch error
status = alt_bridge_init(ALT_BRIDGE_H2F,0,0);
} else {
status = alt_bridge_init(ALT_BRIDGE_LWH2F,0,0);
} else {
status = alt_addr_space_remap(ALT_ADDR_SPACE_MPU_ZERO_AT_BOOTROM,
ALT_ADDR_SPACE_NONMPU_ZERO_AT_OCRAM,
ALT_ADDR_SPACE_H2F_ACCESSIBLE,
ALT_ADDR_SPACE_LWH2F_ACCESSIBLE);
} else {
while(1){
alt_write_word(ALT_LWFPGA_BASE + ALT_LWFPGA_LED_OFFSET, 0x3);
delay(10000);
alt_write_word(ALT_LWFPGA_BASE + ALT_LWFPGA_LED_OFFSET, 0x0);
delay(10000);
// reset watchdog timer
alt_write_word((SOCFPGA_L4WD0_ADDRESS + DW_WDT_CRR), DW_WDT_CRR_RESTART_VAL );
return 0;
