Altera 10AS016E4F27E3SG - Post/Bootup/Reset Error
I am from Venture Corporation Limited Singapore, and we were supplied by Intel this Altera IC 10AS016E4F27E3SG.
We have failed component (10AS016E4F27E3SG) and wants to send for supplier FA unfortunately; Intel representative has advised us to go to this forum and post our inquiry about the failed component.
Is there anybody here can help us to get intel to have our request to perform FA on the failed components and to understand our current problem related to Altera 10AS016E4F27E3SG?
Problem: Post/Bootup/Reset error
Station: Functional Test Station
Qty: 3pcs
Date code: 2431
Lot code: S319AKC66
- Farabi_Altera
I am taking this case from Aiman.
Do you have any update.
regards,
Farabi
- NurAiman_M_Intel
I have provided he DPR form in private email separately.
- Raymart_Julian
Good day Aiman,
Thanks for your response and received the form. I am now working internally on the information that you are asking and will get back to you using the separate email that you have sent to me and send back the form together the 11 questions that you are asking.
- NurAiman_M_Intel
I will help you to file an FACR. Can you help to provide below information and fill in the DPR form attached.
1.- What is the failure symptom? Please elaborate the failure symptom in detail.
2.- When did the failure happen?
3.- How did you discover the failure?
4.- In which part of your process did you found the issue (Lab, production, quality, etc.)?
4.1- Was the device already in Field? For how long?
5.- How many units failed and how many units were used/tested by you?
6.- How did you determine the failure? Please elaborate the procedures.
7.- Does the failure unit was ever working before failure? If yes, how long had it been in use?
8.- How did you rule out that the failures were not caused by an electrical over stress (EOS) or an Electrostatic discharge (ESD)?
9.- What are your expectations of this failure analysis?
10.- Have you Re-ball your device? If yes, Is it lead-free reballing?
11.- Please add pictures of the device from the top and the bottom.
Aiman
- Raymart_Julian
Good day Jeet14,
A kind follow-up on the contact of the FAE for part failure so that i could try to reach them out about my concern. Thanks for the support.
- Jeet14
You need to contact your local FAE for part failure, return/replacement ana FA etc. FAE will raise this request through the IPS.
I will also send their contact through private message. You can reach them.
Tiwari
- Raymart_Julian
Good day Tiwari,
Thanks and regards,
Raymart
- Raymart_Julian
Good day Jeet14,
Thanks for your reply.
Highly appreciate your help and kindly please share the contact so that I could reach them out.
