13 years ago
ALT2GXB on CYCLONE IV GX
Hi every one!
I'm a newbie about the GXB transceivers.
I'm trying to realize a transmission channel very simple using a Cyclone IV GX(EP4CGX15BF14C8N.
) device on a board realized in my company.
In order to test it actually i check if the PLL of the transmitter locks the pll_inclk[0].
I connected the Clock generator to the pin E7 (pll_inclk[0]) . but not in differential mode.
(PIN E6 connected to ground)
Note that the "normal" pll locks to the frequency. (100MHz)
I made a considerable numbers of attempts, but up to now i was not able to use it.
What could be the main problem?
-The clock that is not differential?
-The tranceiver needs a different clock respect to the "FPGA fabric ?"
-or both?
Best regards.
PS: I have a very similar issue on a Stratix II GX Based Board.
    Dear All,
    i found that the clock has to be differential in the Knowledge BAse of Altera.
    (Solution ID: rd05032011_649)
    Please note that the fitter (quartus 12.1) does not give any error.
    Best Regards
    Thank you very much for the reply.
    I'm sorry for the few clarity
    I'll try to amend in the following
    I connected the Clock generator to the pin E7 and the PIN E6 to ground and i configured the PIN E7 as 2.5V (IO Standard)
    I configured the GXB transceiver just as transmitter (protocol BASIC, without 8b/10B)
    The inputs for the transceiver are
    - tx_datain[9..0] connected to a lpm_constant
    -pll_inclk[0] connected to E7
    -cal_blk_clk (connected to E7)
    The clock generator has a frequency of 100 Mhz
    The outputs of the TX transceiver are:
    tx_dataout[]
    pll_locked[0]
    tx_clockout[0]
    The expected result is that the pll_locked Signal goes to "High" Level
    But i did not get it
    As i already mentioned, unsing a normal PLL (altpll Megafunction) and using the same clock the pll_locked signal goes in "HIGH" state.
    I made this test because, looking at the netlist using "Resource Property Editor"tool in QuartusII i saw that the PLL of the transceiver is a separated entity of the transceiver
    and it seems that is the same of the ALTPLL megafunction
    and both are connected to the output pll_locked in the same way.
    Thank you for the hint. I'll try to instantiate also the RX channel.
    About the diff-clk: I searched in the handbook of the Cyclone IV and in the Guidelines for the connection of the pins, but i did not find
    anything of mandatory
    It could be very useful if you could indicate me where i can find this sentence.
    Thanks a lot again
    Best Regards
    Your post does not state what is the result you get, and what you'd expect. Also you do not describe your setup detailed enough.
    Anyway, I had a strange GX problem with Cyclone IV GX.
    I instantiated an RX-only GX unit. I did follow the reset sequence recommendation, but could not see freqlocked signal to activate.
    Finally I found out that if I instantiate TXRX GX and do not use TX path at all, the freqlocked signal behaved as documented.
    If I remember correctly, Altera documentation says that diff-clk is mandatory if using GX blocks. You could probably tie one pin to ground through capacitor, or tie it to a voltage which is middle of input voltage swing. But the jitter performance might suffer.
    If you connect the negative pin to ground, you can not configure the input *** diff (the positive input can never have voltage smaller than negative input).
    BR, -Topi
