13 years agoALT2GXB on CYCLONE IV GX
Hi every one! I'm a newbie about the GXB transceivers. I'm trying to realize a transmission channel very simple using a Cyclone IV GX(EP4CGX15BF14C8N. ) device on a board realized in my...
13 years agoThank you very much for the reply.
I'm sorry for the few clarity I'll try to amend in the following I connected the Clock generator to the pin E7 and the PIN E6 to ground and i configured the PIN E7 as 2.5V (IO Standard) I configured the GXB transceiver just as transmitter (protocol BASIC, without 8b/10B) The inputs for the transceiver are - tx_datain[9..0] connected to a lpm_constant -pll_inclk[0] connected to E7 -cal_blk_clk (connected to E7) The clock generator has a frequency of 100 Mhz The outputs of the TX transceiver are: tx_dataout[] pll_locked[0] tx_clockout[0] The expected result is that the pll_locked Signal goes to "High" Level But i did not get it As i already mentioned, unsing a normal PLL (altpll Megafunction) and using the same clock the pll_locked signal goes in "HIGH" state. I made this test because, looking at the netlist using "Resource Property Editor"tool in QuartusII i saw that the PLL of the transceiver is a separated entity of the transceiver and it seems that is the same of the ALTPLL megafunction and both are connected to the output pll_locked in the same way. Thank you for the hint. I'll try to instantiate also the RX channel. About the diff-clk: I searched in the handbook of the Cyclone IV and in the Guidelines for the connection of the pins, but i did not find anything of mandatory It could be very useful if you could indicate me where i can find this sentence. Thanks a lot again Best Regards
