16 years agoAllowed voltage levels on Stratix IV GX configuration pins?
Most of the Stratix IV GX configuration pins are powered from a dedicated supply, VCCPGM, that can be 3/2.5/1.8V.
Are min/max input and output voltage levels on those configuration pins the same as for an appropriate LVTTL standard (e.g. does VCCPGM=2.5V means that DCLK supports LVTTL25 voltage levels)?2 Replies
OK, then if VCCPGM is 2.5V then input configuration pins will sustain VIH max of 3.6V as it's defined for 2.5V LVTTL/LVCMOS I/O in Table 1-16 of the "Stratix IV Device Handbook. Volume 4. Chapter 1. DC and Switching Characteristics"
Yes, you can simply assume that these pins are using identical I/O cells, unless explicitely specified different.
