16 years agoAllowed voltage levels on Stratix IV GX configuration pins?
Most of the Stratix IV GX configuration pins are powered from a dedicated supply, VCCPGM, that can be 3/2.5/1.8V. Are min/max input and output voltage levels on those configuration pins the same a...
16 years agoYes, you can simply assume that these pins are using identical I/O cells, unless explicitely specified different.
