3LionsCT's avatar
3LionsCT
10 months ago
Agilex Reset_Release no associated clock
I wonder if anyone can help me with a Platform designer error while using the Agilex Reset release IP. I wanted to combine the nInit_done signal with a couple of external resets to make a global reset. I added the Agilex Reset release IP and I combined it with my external resets in a separate HDL module that I wrote (see attached).
I now have a system_platform error telling me that the reset_release IP and my HDL module have to be on the same clock domain (see attached) and that the reset_release IP has no associated clock.
Does anyone know how to associate a clock with the reset release IP? I have tried everything I can think of but no luck
  • Hi 3LionsCT,
    The reset release IP's ninit_done signal is asynchronous, so there is no associated clock. From your RTL, the reset you are generating also is asynchronous so when you make the reset source in your _hw.tcl you need to set SYNCHRONOUS_EDGES to none.
    Can you share the _hw.tcl for your global_reset IP?
    • 3LionsCT's avatar
      3LionsCT
      Hi Kbrunham,
      Thanks for the reply. You are indeed correct, I had set the synchronous-edges incorrectly. I changed it and it removed the errors
      Thanks again
      • BoonBengT_Altera's avatar
        BoonBengT_Altera
        Icon for Moderator rankModerator
        Dear Customer,
        I'm glad that your issue is resolved. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
        Altera Technical Support
